jsontemplater - using pipe within an array
  • February 13, 2025
  • 72 views
tb09114
Forum|alt.badge.img+27
I want to build a flat JSON array using the jsontemplater. I try to use this example to understand the syntax but using the pipe character does not go well.
Starting with a simple creator for the root object and sending the actual information to the ‘ADDRESSES’ sub template.
I try to define the root template as
fme:process-features("ADDRESSES")
and the sub template as
"ID": fme:get-attribute("Site_ID"),
"Address": fme:get-attribute("Address")
Taking it from the linked example the pipe character is needed to separate the array items by commas.
My translation log return the following warnings, and error message
JSONTemplater (XMLTemplaterFactory): The following error occurred near line 1, column 3 of the query:
JSONTemplater (XMLTemplaterFactory): invalid expression: syntax error, unexpected "|"
JSONTemplater (XMLTemplaterFactory): An error occurred while parsing the ROOT template
How do I use the jsontemplater to create some flat JSON array structured as
"ID": "Site_ID",
"Address": "Address"
"ID": "Site_ID",
Best answer by tb09114
Okay, I found it out.
For the flat array, there is no need to use the pipe |. Simply delete the pipes from the root template and the array is created as expected.
tb09114
  • February 15, 2025
danilo_fme
Forum|alt.badge.img+53
  • February 17, 2025
Hi ​@tb09114
Yes, you are correct.
