JSON Writer Issue
  • Nov 15, 2018 9:34 PM UTC
  • 194 views
Hello: I have a workspace that I attempted to write a JSON file with the JSON writer. The problem is, the structure of the JSON has a SUB associated with it and the SUB features are not produced with the write. I'm currently using the text file writer where it simply writes the text_line_data from my JSONFormatter. The problem with this approach is that the output are strings and I have some fields that must be numeric. I saw on another thread to dynamically convert the strings to int/double using the xs:int(attribute) or xs:double(attribute) function. This approach is fine BUT there are some number values that have NULL and in order to use the xs function, I've discovered these attributes can't be NULL. Can't I take care of this using the JSON writer by setting the datatype of the output? But again I can't seem to get the JSON writer to generate my SUB features.
  • Nov 15, 2018 10:23 PM UTC
The xs:interger function and the xs:double function convert <missing> attribute to null. Try changing every <null> and <empty> to <missing> with the NullAttributeMapper before the JSONTemplater.
  • Nov 15, 2018 10:30 PM UTC
@takashi - I had a NullAttributeMapper in there before the JSONTemplater but had all values checked (empty, missing, and null). I just made the adjustment you suggested and received these errors:
JSONTemplater(XMLTemplaterFactory): The following error occurred near line 5, column 35 of the query:
JSONTemplater(XMLTemplaterFactory): "xs:string": invalid value for cast/constructor: can not cast to "xs:double"
JSONTemplater(XMLTemplaterFactory): A fatal error has occurred. Check the logfile above for details
Here's what's in the JSONTemplater:
"totalInvestment": xs:double(fme:get-attribute("totalInvestment")),
"squareFootageRetail": xs:double(fme:get-attribute("squareFootageRetail")),
"squareFootageOffice": xs:double(fme:get-attribute("squareFootageOffice")),
"squareFootageManufacturing": xs:double(fme:get-attribute("squareFootageManufacturing")),
"recordType": fme:get-attribute("recordType"),
"projectStage": fme:get-attribute("projectStage"),
"projectName": fme:get-attribute("projectName"),
"projectId": fme:get-attribute("projectId"),
"projectDescription": fme:get-attribute("projectDescription"),
"projectDate": fme:get-attribute("projectDate"),
"propertyAddresses":[
fme:process-features("SUB")
"programType": fme:get-attribute("programType"),
"numberOfUnits": xs:double(fme:get-attribute("numberOfUnits")),
"numberOfSqFt": xs:double(fme:get-attribute("numberOfSqFt")),
"numberOfParkingSpaces": xs:double(fme:get-attribute("numberOfParkingSpaces")),
"numberOfHotelRooms": xs:double(fme:get-attribute("numberOfHotelRooms")),
"neighborhood": fme:get-attribute("neighborhood"),
"jobsRetained": xs:double(fme:get-attribute("jobsRetained")),
"jobsCreated": xs:double(fme:get-attribute("jobsCreated")),
"developer": fme:get-attribute("developer"),
"category": fme:get-attribute("category"),
"cagisId": fme:get-attribute("cagisId"),
"address": fme:get-attribute("address")
  • Nov 15, 2018 11:07 PM UTC
Make sure that you have changed <null> and <empty> to <missing> with the NullAttributeMapper.
However, if the attribute stored a character string not representing a numeric value, the error would still appear since the NullAttributeValueMapper doesn't remove that. Please check what value is stored using the Logger or the Inspector.
  • Nov 16, 2018 1:07 AM UTC
Thanks. I attempted to convert one of my attributes to an integer in an attributemanager and neglected to back that out. That did the trick. Thanks!
