JSON to JSON LD
  • Dec 23, 2019 2:27 PM UTC
  • 13 replies
  • 229 views
jasperwis
Forum|alt.badge.img+19
I am looking for advice how to turn a JSON file into a JSON LD (linked data) with FME.
This is an example of a JSON LD format
https://json-ld.org/spec/latest/json-ld-framing/#example-3-flattened-library-objects
There are 2 parts:
1) @context: where you place the link to the complete vocabulary of the model
2) @graph: where the features are written.
How can I introduce these 2 parts when writing JSON in FME?
Jasper
jdh
Forum|alt.badge.img+41
  • Dec 23, 2019 2:41 PM UTC
I think you'll need to structure your data with a JSON templater.
The root object would contain your context information and the features would be a subtemplate.
Depending on your source data, you could use a creator for the root, or a sampler on you data with the 1st feaure going to both the root and the subtemplate (with a group by if you have more than 1 context in your data).
jasperwis
  • Dec 23, 2019 3:31 PM UTC
I experimented a little with the JSONTemplater, but i was not able to write the @context and @graph part succesfully yet.
Can you put me on the right track?
json_LD_test.fmw
jdh
  • Dec 23, 2019 4:02 PM UTC
json_LD_test.fmw
because the JSONTempater already structures your data, you can use a text writer rather than a json writer you output your data. Set the result attribute on the templater to text_line_data.
Presumably you want a sampler to send only one feature to the root.
Also the subtemplate should be a json object per the spec, not just an array of ids.33054-json-ld-test.fmw
jasperwis
  • Dec 23, 2019 4:30 PM UTC
Great. Thank you for the help.
One more question: is it possible to write all available attributes for the Sub Template at once?
The name of the attribute identical to the name in fme.
Or do I need to define it attribute by attribute?
jasperwis
jdh
  • Dec 23, 2019 5:36 PM UTC
There may be way using xquery and for loops, but I don't know it well enough to say.
jasperwis
  • Dec 24, 2019 7:29 AM UTC
Thank you for the help jdh.
@takashi Do you have a solution for writing all attributes in the sub template without defining them individually?
  • Dec 24, 2019 7:55 AM UTC
Maybe possible, but how to depends on structure of the source JSON document. Can you post a source example and your desired result that should be generated from the source?
jasperwis
  • Dec 24, 2019 8:09 AM UTC
Hi Takashi,
It's the extension of the topic you helped me with.
https://knowledge.safe.com/questions/104798/json-to-flat-table.html
source.jsondesired_output.jsonjson_LD_workinprogress.fmw
  • Dec 24, 2019 8:38 AM UTC
Looks like the destination "@graph" array is exactly equal to the source "collection" array. Isn't it?
If my observation above was correct, it's not necessary to perform either fragmentation or flattening the JSON document at all. Just extract the "collection" array and build your desired JSON structure containing it.
Example:
    "@context" : "http://www.google.be/context",
    "@graph" : fme:get-json-attribute("_collection")
This could also be available.
    "@graph" : fme:get-json-attribute("text_line_data")("collection")
jasperwis
  • Dec 24, 2019 9:01 AM UTC
Example:
Works perfectly.
I see one disadvantage for this solution, I think there is no flexibility to add or change attributes. Am I correct?
To get a correct JSON LD, I would like to add "@id" and "@type" later.
  • Dec 24, 2019 9:30 AM UTC
If you need to add @id and @type element to every object in the array, this workflow example might help you.
Root Template Expression:
    "@graph" : [ fme:process-features("SUB") ]
SUB Template Expression:
    {"@id" : 1},
    {"@type" : "something"},
  • Dec 24, 2019 9:34 AM UTC
How do you determine the values of @id and @type?
