Json to features
  • June 17, 2014
  • 7 replies
  • 163 views
Dear All ,
I use geometry replace to convert json to feature , but it doesn't work it give an error , I tried geojson and esrijson both give an error , below is the json text which stored in a feature class .
    "geometryType": "esriGeometryPolygon",
    "hasZ": false,
    "hasM": false,
    "features": [
            "geometry": {
                "rings": [
                            6055422.478793681,
                            2809493.0711957584
                            6055818.269231402,
                            2809235.807411239
                            6055646.760041723,
                            2808978.5436267196
                            6055293.8469014205,
                            2808998.333148606
                            6055211.390560228,
                            2809206.12312841
                            6055422.478793681,
                            2809493.0711957584
            "attributes": {
                "GraphicType": "ProposedPlot",
                "IsSaved": "False"
gio
Forum|alt.badge.img+15
  • June 17, 2014
I copied your json adn paste it to a txt file. I read it with esrijson and get a 5 sided ploygon...no errors.
How have u stored this json object?
  • June 17, 2014
Thanks GIO , We are storing the features in to SQL server within ntext attribute
gio
  • June 17, 2014
I read that ntext is a single variable length string.
I made it one string and removed all spaces. It still works fine.
Maybe one or more json objects have a character count wich is too long for the field written too?
(i understand that the format definition is written ntext(n) where n is legth)
You could do a character count to see wath max. legth is of json objects.
You could go for nvarchar instead of ntext? Wich is what everyone advises.
ntext seems to be a depricated format btw.
gio
  • June 17, 2014
you can use this to count characters
use a creator to make
char_count = @Evaluate([llength [split @Value(col0) {}]])
  • June 17, 2014
Hi ,
It is not a problem of charcter length , I tried it for the record I sent and still I am getting an error . Thanks ,
  • June 17, 2014
I myself have no practical experience on JSON, but possibly the JSONFragmenter transformer with this query helps you to extract geometry objects from the full JSON document.
JSON Query: json["features"][*]["geometry"]
Takashi
gio
  • June 17, 2014
Then maybe a faulty object (json incorrect) is in the dataset?
The only way i get it to yield an error is by remoinge somee brace, bracket or other punctuation mark so it can't parse it no more...
