JSON Templater float attributes populated as strings
  • Oct 28, 2014 4:25 PM UTC
  • 130 views
I am using the JSONTemplater with such Root Expression:
    "Code" : fme:get-attribute("Code"),
    "Nom" : fme:get-attribute("Nom"),
    "C3" :
            "label" : "2006",
            "value" : fme:get-attribute("C3_EII06")
            "label" : "2007",
            "value" : fme:get-attribute("C3_EII07")
            "label" : "2008",
            "value" : fme:get-attribute("C3_EII08")
            "label" : "2009",
            "value" : fme:get-attribute("C3_EII09")
            "label" : "2010",
            "value" : fme:get-attribute("C3_EII10")
            "label" : "2011",
            "value" : fme:get-attribute("C3_EII11")
The "values" in the C3 list are all float attributes but the Templater populated them with quotes in the output json. Why? How can I ensure the values to stay in float format?
Best answer by david_r
have a look here: http://fmepedia.safe.com/AnswersQuestionDetail?id=906a0000000clKgAAI
David
  • Oct 28, 2014 4:52 PM UTC
Update to my question:
I look into the Input Feature Type into the User Attributes tab and all attributes are in float Type. However, I do put an Inspection Point on the connection between the reader and the JSONTemplater and I see that all attributes have (string) beside them. Does it means that they are already converted into the string type from the reader?
  • Oct 28, 2014 5:42 PM UTC
  • Oct 28, 2014 6:00 PM UTC
Thank you David
jnotter
Forum|alt.badge.img+7
  • Jan 28, 2020 11:01 PM UTC
It doesn't look like that link goes to a specific entry on fmepedia. Perhaps an updated URL?
