JSON from ActiveMQ not writing to database.
  • Oct 16, 2023 3:51 PM UTC
  • 96 views
dkirouac
Forum|alt.badge.img+5
I have a workspace that I am using a JMSReceiver to receive JSON files from ActiveMQ. I am then using a JSONFlatterner to parse out the JSON fields. When I write the output to an email the attributes get sent to the email body as expected. But when I try writing the same output to a geodatabase feature class or a text file the attributes do not write. In the case of the text file the variables are identical to the variables for the email body - works for the email but not the text file. Am I missing a step that is causing the output not to be written to the text file or geodatabase?
@Value(P_LINK_ANNTENUATION)
@Value(P_LINK_ANTENNA_AZIMUTH)
@Value(P_LINK_ANTENNA_HEIGHT)
@Value(P_LINK_ANTENNA_TYPE)
@Value(RTU)
@Value(SCADA_DB_RTU_ID)
Forum|alt.badge.img+54
  • Nov 21, 2024 3:30 PM UTC
Did you ever get anywhere with this?
  • Nov 22, 2024 3:08 PM UTC
I can write some data to a gdb by using a time windower and group processing with “Complete Groups when Group Changes” set
However, there doesn’t appear to be anyway to write data in a timely manner if there is a gap or the last batch if you manually stop the process.
Stated here.
What's Up Wednesday (2-November-2022): Streaming to a Database, Mapping Month Webinars, Conference Videos, and (yes) much more! | Community
“Another interesting twist is that the data isn't written until a feature with a new time window arrives. If there is no new feature, the old data doesn't get written. So that's just something to be aware of.”
