Json attributes extraction
  • Jul 27, 2018 3:27 PM UTC
  • 5 replies
  • 666 views
boubcher
Forum|alt.badge.img+11
How to extract the attribute from the Json file , with the content
I trauied all Json transformer but did give me what I am looking for
Json content
[{"code":"EPSG:4326"},{"x":"41.86306379123165","y":"19.05070466974152"},{"x":"41.86136208513543","y":"19.048743553071773"},{"x":"41.8575815484205","y":"19.05212744890353"},{"x":"41.86306379123165","y":"19.05070466974152"}]
we want this
Best answer by daveatsafe
Hi @boubcher,
You can use the JSONFragmenter to break up the JSON records, and flatten into feature attributes. Then you can separate the code record and apply it the following locations using a VariableSetter and VariableRetriever.
flattenjson.fmw
geosander
Forum|alt.badge.img+7
  • Jul 27, 2018 3:33 PM UTC
If that is what you need, and you have write access to the JSON document, you might consider restructuring your JSON, because this reeks of bad data modeling (sorry). It will be a whole lot easier to read/transform!
danilo_fme
Forum|alt.badge.img+58
  • Jul 27, 2018 3:46 PM UTC
Hi @boubcher
I simulated here in my Workspace with some transformers:
Results in FME Data Inspector:
Attached the Workspace - workspace-json.fmw
Thanks,
Danilo
daveatsafe
Forum|alt.badge.img+24
  • Jul 27, 2018 3:58 PM UTC
Hi @boubcher,
flattenjson.fmw
boubcher
  • Jul 28, 2018 6:06 PM UTC
Hi @boubcher,
flattenjson.fmw
the variable setter and retriever transformer are great
I can used them in many cases I have
Thanks
  • Jul 29, 2018 8:54 AM UTC
Another thought. This workflow reconstructs the JSON document then fragments/flattens that.
Template Expression in the JSONTemplater: Assuming the the input feature has an attribute called "_json_doc" which stores the original JSON document.
    let $m := fme:get-json-attribute('_json_doc')
    for $i in (2 to jn:size($m))
    return { "code" : $m(1)("code"), "x" : $m($i)("x"), "y" : $m($i)("y") }
