jpeg to correct location
  • Dec 24, 2022 3:14 PM UTC
  • 11 replies
  • 154 views
gvenhorst
Hi.
JPG photo from a DJI drone contains coordinates in the EXIF ​​but is not displayed in the correct location.
JennaKAtSafe
Forum|alt.badge.img+9
Hi @gvenhorst​, sounds like you need to play with the coordinate system of your JPG. Here is a great article to get your started with manipulating coordinate systems: https://community.safe.com/s/article/using-coordinate-systems-within-fme
gvenhorst
  • Dec 29, 2022 6:44 AM UTC
Have already tried various settings and read documentation, but the DJI has a slightly different Exif info.
Whichever setting I use, the top left corner of the photo will always be at coordinate 0.0.
Forum|alt.badge.img+63
Can you post a screenshot of the EXIF information you're getting?
gvenhorst
  • Dec 29, 2022 9:58 AM UTC
Hoi,
 Hierbij een screenshot.
Screen Shot 12-29-22 at 11.03 AM
Just as I thought, the latitude/longitude are given in WGS84, degrees, minutes and (decimal) seconds. You need to use an AttributeSplitter, with a space as separator character, first to separate them into list elements and then a DecimalDegreesCalculator to turn them into decimal degrees.
Then an Offsetter or Georeferencer to turn your jpg into a georeferenced one (although if it's supposed to be a top-down photo and the drone wasn't completely level when the photo was taken that might be a whole other ordeal).
gvenhorst
  • Dec 29, 2022 12:34 PM UTC
Thank you for thinking along.
Converting the coordinates works well (had already tried that before).
But the next step keeps going wrong.
Or I come from somewhere in the sea or in Africa.
The photo was taken in the Netherlands, Limburg.
If I look up the coordinates on the map, I get to the right place.
N51.17425933333333 E6.021244194444445
Okay, then a CoordinateSystemSetter, using LL84 as the coordinate system, should do the trick.
gvenhorst
  • Dec 29, 2022 1:12 PM UTC
Had tried that
The top left corner is in the right place but the grid is now much too large
Screen Shot 12-29-22 at 02.10 PM
Do you have more information in the exif data? I see an altitude in there as well, along with the focal length that should tell you something about the size of the image on the ground, but even then I think that's not quite enough yet.
gvenhorst
  • Dec 29, 2022 1:24 PM UTC
Can I email you the photo and fme model?
I think it's better if you post them here so that others can try and help you. I'm not sure I have the answers for you (as we're getting into photogrammetry here and that's not my strong side), nor the time what with the holidays.
In addition to that, if somebody here provides the correct answer and others find this thread later on they might be helped by it too.
