Joining and Sorting
  • Jun 15, 2019 4:11 AM UTC
  • 52 views
sunsilk11
Hi I have the following table after doing a database query
ID overlaps Count Email
0 2 1 PublicOps@sts.com
0 2 1 PrivateOps@sts.com
1 7 3 PublicOps@sts.com
1 7 3 PrivateOps@sts.com
1 7 5 PublicOps@sts.com
1 7 5 PrivateOps@sts.com
2 5 3 PublicOps@sts.com
2 5 5 PrivateOps@sts.com
For each ID, I need to retain the records with maximum count i.e.
for example above, I need to output to be
Following this, I need to join output with table 2 to determine if the count is higher than the level value
for each ID. If it does retain in output, otherwise discard record from table 1
Table 2
ID Level
0 1
1 3
2 3
Hence output expected is:
I have tried using a sorted a Sorter group by ID/Count/Address , followed by a Sampler
but I am not getting the desired output
Any suggestions?
Best answer by takashi
A possible ways is: calculate the maximum of Count value for each ID with the StatisticsCalculator, merge Level to the features with the FeatureJointer, then filter them with the Tester according the criteria - Count = max count AND Level < Count. The FeatureMerger or the DatabaseJoiner can also be used instead of the FeatureJointer.
Alternatively, if the two tables belong to an identical database, you could get the result by executing a single SQL statement. e.g.
select a.* from table_1 as a
inner join (select ID, max(Count) as max_count from table_1 group by ID) as b
on a.ID = b.ID and a.Count = b.max_count
inner join table_2 as c
on a.ID = c.ID and c.Level < a.Count
  • Jun 15, 2019 6:44 AM UTC
