Join Shapefile with property data
  • Oct 11, 2019 5:36 PM UTC
  • 7 replies
  • 106 views
I want to categorize all properties across BC based on the federal electoral districts. I have the Esri Geodatabase file format for the federal electoral districts and have all the properties with their latitude and longitude information stored in a table. what will be the best approach to resolve this ?
Best answer by fmelizard
Hi @vakansha You're likely creating points with the VertexCreator. Use a PointOnAreaOverlayer instead of the AreaOnAreaOverlayer. Or use a SpatialRelator or SpatialFilter.
erik_jan
Forum|alt.badge.img+26
  • Oct 11, 2019 5:41 PM UTC
Since both data sets should not have overlapping polygons, The AreaonAreaOverlayer (merge attributes) should give you the set of parcels with the electoral district information added.
Some parcels (on the boundary of the districts) might get duplicated.
Hope this helps.
  • Oct 11, 2019 5:54 PM UTC
Hope this helps.
Everything is rejected. Why is that?
fmelizard
Forum|alt.badge.img+22
  • Oct 11, 2019 6:00 PM UTC
fmelizard
  • Oct 11, 2019 6:04 PM UTC
Hello @danatsafe even when i use a PointOnAreaOverlayer, it gives me either only the points or only the BC shape file but not both of them together.
fmelizard
  • Oct 11, 2019 6:06 PM UTC
Are both datasets in the same coordinate system? Did you generate a list on the PoAO for both Point and Area outputs?
  • Oct 11, 2019 8:25 PM UTC
It worked finally. I was not generating a list on PoAO which is why it was not working. Thanks for your help.
