Join records with Line geometry
  • August 20, 2025
  • 66 views
syedh2993
Forum|alt.badge.img+7
Hi All,
I am working on data with Line Geometry and would require some help to solve the below scenario,
While plotting them on map, I see there is small gap between lines in some scenarios and would like to join them together if the distance between two lines is less.
(Reason for this gap - There is an asset in between the lines which has Point geometry.- Not sure if this statement will help, JFYI)
Below is an example of different line geometries joining with each other, and there are small gap in some scenarios
I would like to join
  1.  gap between Line 3 and Line 4.
  1. gap between Line 5 and Line 6
I am not interested in joining parallel line, as they are far from each other
Any help regarding the above would be much appreciated.
Thanks
lambertus
Forum|alt.badge.img+24
  • August 20, 2025
Hi ​@syedh2993, how about a AnchoredSnapper combined with a LineCombiner?
First one snaps the lines together, 2nd merges adjacent lines into single lines.
syedh2993
  • August 25, 2025
Hi ​@lambertus : Thank you so much for your response.
In my case, I only have 1 file with all the data. I see “AnchoredSnapper” requires 2 inputs
and I think I missed adding few more sentences, I have updated my question.
  1.  small gap between Line 3 and Line 4.
  1. small gap between Line 5 and Line 6
I am not interested in joining parallel line, as they are far from each other.
Thanks
lambertus
  • August 25, 2025
@syedh2993 thanks for your update. Could you share a dataset I can play around with in order to build a suitable workflow for you?
