Join multiple unit tables to one main geometry table based on one common_id field.
  • Jan 8, 2020 4:14 PM UTC
  • 28 views
sudhakary
Forum|alt.badge.img+3
I want to join multiple unit tables to one main geometry table based on one common_id field.
The scenario as follows
Main_Table1 ===> Unit_Table1
Main_Table1 ===> Unit_Table2
Main_Table1 ===> Unit_Table3
Main_Table2 ===> Unit_Table1
Main_Table2 ===> Unit_Table3
Main_Table2 ===> Unit_Table4
Main_Table2 ===> Unit_Table5
Main_Table3 ===> Unit_Table1
Main_Table3 ===> Unit_Table5
Main_Table3 ===> Unit_Table6
The main table is having the geometry and the unit tables are having the attributes. One unit table contains attributes of multiple geometry tables as shown above.
jovitaatsafe
Forum|alt.badge.img+11
Hi @sy0520,
If I'm understanding correctly that you're looking to merge additional attributes to a table schema based on a common ID, this tutorial on the FeatureJoiner might be a helpful place to get started on your workflow. Hope that helps a bit!
