java.lang.NumberFormatException when writing to MS Azure SQL data base
  • May 29, 2023 5:18 PM UTC
  • 0 replies
  • 40 views
arthy
Forum|alt.badge.img+8
hello,
I'm having several java.lang.NumberFormatException: warning when writing to MS Azure SQL database.
imageIt does not prvent the workspace to run properly however, it create a very long log file with hundreds of thousands of warnings. Is there a way to correct that so that I won't have such warning anymore?
Thanks
