Java-Factories in FME2013
  • February 13, 2013
  • 42 views
Hi!
I'm installed the FME2013 an put my own Java-Readers/Writers/Factories in the plugin directory. The Readers and Writers run without problems. When I use my factories, FME send message:
This FME edition does not recognize the `de.geocalc.fme.factory.ColorizerFactory' factory. Please ensure that the current platform supports this factory, the factory name is spelled correctly, and that you have installed all required plug-ins
Must I register the Java-Factories under FME2013?
2. Question:
Can I use a shared plugins-directory? I need the plugins under 32bit and 64bit version of FME.
Best answer by tino
Hi Joerg,
have a look at the example files in <FMEHOME>\\pluginsinfo.
With FME 2013 you need for every plugin (function/factory) a db (text) file which defines name,path and type of a plugin.
I am not sure about your second question, but i think you'll have to deploy your plugin twice.
tino
Forum|alt.badge.img+28
  • April 11, 2013
Hi Joerg,
