Iterate through individual GDBs and Merge FCs with same name
  • Nov 30, 2023 4:02 PM UTC
  • 101 views
galigis
Forum|alt.badge.img+22
Hi All,
I'm trying to create a workflow that iterates through a folder which contains individual GDBs (e.g. 20 individual GDBs) and then merges the Feature Classes with the same name into a new blank GDB.
Any idea how to make that happen?
Thanks 🙂
Best answer by takashi
Hi @galigis ,
You can read all the *.gdb folder paths from the folder with Directory and File Pathnames reader (PATH), read all the features from the gdb datasets with FeatureReader, and write them into a single gdb dataset with a gdb writer using Dynamic Schema setting. Send the schema features output from the <Schema> port of the FeatureReader to the destination writer as schema definition features.
The workflow looks like this.
workflowdynamic-writer-setting
  • Dec 1, 2023 11:24 AM UTC
Hi @galigis ,
galigis
  • Dec 1, 2023 12:36 PM UTC
Hi @galigis ,
Bravo. It worked! :)
