Iterate through a table based on a list of values
I would like to iterate through a table based on a list of values. This is the process I would like to automate:
Filter the table on a value then add an attribute and BulkAttributeRenamer. I have 20 values so I'd like to be able loop through the table for each value rather than have a set of transformers for every value.
Best answer by ebygomm
It's not 100% clear what you're trying to do. Perhaps this sort of workflow is what you're aiming for?
imageThe only change if you have 20 values would be additional attributes to expose in the AttributeExposer
  • August 17, 2022
@vcarr2005​ Can you attach a small example dataset. It looks like you should be able to do this in series
  • August 18, 2022
Thank you, Mark. I've attached a file
Forum|alt.badge.img+32
  • August 18, 2022
  • August 19, 2022
Thank you @ebygomm! This is exactly what I needed. I had created something similar but I didn't have the Aggregator configured correctly.
