Issues "transposing" a table in FME
  • May 18, 2020 11:42 AM UTC
  • 5 replies
  • 85 views
Hello, I am having some issues getting the proper format of a table I am trying to transpose. I attempted a couple of methods using the FMEHub AttributeTransposer and did not get the required results. If you see it is almost a half transpose, I need to get the records in the first sheet to line up like the records in the second sheet in the attached spreadsheet . I have hit a roadblock.
There is a video tutorial. I've done it a few times and it works fairly well.
https://knowledge.safe.com/articles/31701/transpose-a-table-using-fme.html
Forum|alt.badge.img+54
  • May 18, 2020 12:28 PM UTC
This is how I would approach this
  1. Create a the new attribute named according to the Filter type
  2. Aggregate the records based on the name
  3. Expose the newly created attributes
  4. Remove the now unneeded filter attributes
You probably also want a null attribute mapper if you want missing values to be set to 0
  • May 18, 2020 1:20 PM UTC
Thank you for the help! I cannot tell what I am doing wrong here?
  • May 18, 2020 1:28 PM UTC
In the attribute creator you have not selected the Filter type attribute correctly, you need to use the drop down arrow, and choose attribute value, then choose filter type. It should then display as @Value(FILTER_TYPE)
  • May 18, 2020 1:40 PM UTC
Oh jeez, Amazing! Thanks so much.
