Issue with date time converter
  • Feb 19, 2020 7:41 PM UTC
  • 103 views
gogopotter90
Forum|alt.badge.img+14
i want to convert from date format 01.12.2000 to 2000 in one attribute
some times it is working great with my input excel files and some files show me this msg .
The below feature caused the translation to be terminated
DateTimeConverter_2_<Rejected>(TeeFactory): DateTimeConverter_2_<Rejected>
what is important for me to read the last 4 digit
Could someone provide me solution for this issue .
Thanks for help
Best answer by ebygomm
You'd normally get that message when you try and convert a value that isn't a date. If you only ever need the last four digits you could get this without converting the date using the following in an attributecreator
@Right(@Value(attrname),4)
But best to check the rejected data as it sounds like you have some data that doesn't contain a date. If you have some null or empty values, you can set the DateTimeConverter to pass through empty or null values
Forum|alt.badge.img+54
  • Feb 19, 2020 7:51 PM UTC
gogopotter90
  • Feb 20, 2020 11:03 AM UTC
Thanks for ur reply ,and explaination . i will check that
gogopotter90
  • Feb 20, 2020 4:08 PM UTC
@ebygomm Thanks man but i write left instead of right bcs it reads the date not correct,idk why 04.11.2010 it reads  2010.11.04 and u were right i have null in date but it is okey nw but do u know solution of readin date in wrong direction ,i did left instead of right so it is correct but if i want to fix it.what should i do
  • Feb 20, 2020 4:29 PM UTC
Do you have the input format set? Is the date you've given the 4th November or the 11th April? If the 4th of November the Input Format should be %Y.%m.%d$
