Issue Reprojecting Shapefile from SIRGAS 2000 to WGS84 in FME
  • Sep 3, 2025 4:49 PM UTC
  • 5 replies
  • 120 views
francisco_1988
Forum|alt.badge.img+5
Hello everyone,
I’m having trouble reprojecting a shapefile. The file is currently in SIRGAS 2000, and I need to convert it to WGS84. However, when I run the reprojection, an error occurs (see attached image).
Additionally, I need to extract the current coordinate system of the shapefile. In the table, the field shows up as _FME_0, but it should display SIRGAS 2000.
Does anyone know how to fix these two issues?
hkingsbury
Forum|alt.badge.img+73
  • Sep 3, 2025 8:19 PM UTC
Have you tried setting the Source Coordinate System in the Reprojector to SIGRAS 2000?
It seems the FeatureReader isn’t correctly reading the coordinate system
francisco_1988
I need the shape writer to be dynamic, as I need to read shapefiles in different projections.
  • Sep 4, 2025 12:17 AM UTC
Instead of EsriReprojector, how about using another reprojector transformer - e.g. Reprojetor or CsmapReprojector?
francisco_1988
Hi Takashi! In the example I sent as an attachment, I'm already using Reprojector. Do you recommend using ESRI Reprojector? Is that what you meant?
  • Sep 4, 2025 12:53 AM UTC
Oh, I got it wrong.
Try changing the Reprojection Engine parameter of the workspace from Esri to FME and resetting the Destination Coordinate System parameter in the Reprojector to "LL-WGS84" or "EPSG:4326".
