Is UUIDGenerator generating UUID version 4?
  • Aug 28, 2018 3:15 PM UTC
  • 163 views
gtiemens
Is the UUIDGenerator using the algoritm to generate IETF UUID version 4 (random) ? If so, can you add to documentation with reference to the IETF standard ? If it is version 4 (random), can you explain which library is used as seed for the random number?
Best answer by hollyatsafe
Hi @tiemens_g,
The function the UUIDGenerator relies on respect OS api calls to generate UUIDs:
Dependent on your system you should be able to find out which algorithm these functions use.
  • Aug 28, 2018 6:48 PM UTC
Hi @tiemens_g,
  • Sep 30, 2020 8:39 AM UTC
Hi @tiemens_g,
it is my understanding that you can refer the version of a UUID from the typical 8-4-4-4-12 representation (AAAAAAAA-BBBB-CCCC-DDDD-FFFFFFFFFFFF) by
  1. Checking for current variant: Test if the first bit of the DDDD-part equals to 8, 9, A or B.
  2. Get the first bit of the CCCC-Part and treat it as version information. Hence, if this bit is 4, the generated UUID is version 4 (randomly generated).
Also, have a look at:
Based on that, it is my conclusion that UUIDGenerator simply returns randomly created UUIDs (version 4).
Having to work with UUID (in FME) myself I stumbled upon your question. It seems to me, that there was no answer regarding the version used of UUIDGenerator, yet. Unfortunately, the transfomer's documentation is very sparse....
