How could i save the output in inspector automatically in pdf file ,
i do not want to click on save Data as and choose the type of file Pdf manuel for every time.
is there a method to save it automatically ?
and also i want to write some legend (as red : way ) at the left down corner for the output in inspector,
How could i achieve that ? Thanks for help
Not through the Data Inspector, but you can set up a workflow in Workbench that uses a PDF writer. You'll need to position your data and other elements on the page using the PDFPageFormatter
"The FME Data Inspector isn’t designed to be a form of GIS or mapping application. It has no all-around analysis functionality, and the tools for symbology modification and printing are rudimentary and intended for data validation rather than producing map output."
https://desktopmanualbasic.safe.com/DesktopBasic1Basics/1.11.IntroductionToDataInspector.html
thanks for reply, i have watched thic video and it is more clear now.
https://community.safe.com/s/article/creating-pdf-cartographic-output-2016
Thanks for help
Thanks,i got it
Thanks,i got it
Also..I wasnt aware of 'save data as' tool, so I also learned something new
