Is there any way to access/export/restore features in a temporary file?
  • Jul 20, 2023 8:57 AM UTC
  • 75 views
Hi all,
I have a lengthy workbench running. I can see the temporary files being written to the relevant 'wb_run...' folder specified in the translation log. The workbench has just finished writing outputs of an AreaOnAreaOverlayer, and those outputs are now being used as the input to a Dissolver, which is in progress at the moment. I can see a 29GB file named 'FME_OBJC_DissolverInputAreas...'. Is this a temporary hold of the AreaOnAreaOverlayer output features? If so, is there any way to use this temporary file and access/export the features in it? In case it is relevant - I have feature caching turned off.
Thanks!😀
hkingsbury
Forum|alt.badge.img+73
  • Jul 20, 2023 9:18 PM UTC
It should just be an FFS, so you can use the FFS reader to open it
