Is there any difference in calculated values between AttributeCreator and ExpressionEvaluator?
  • April 1, 2020
  • 25 views
bwn
Forum|alt.badge.img+26
As per the topic: Any difference in the values calculated by either Transformer when using @Evaluate in AttributeCreator vs ExpressionEvaluator?
Forum|alt.badge.img+62
There shouldn't be, they're using the same underlying library.
