Is there abilities to iterate through multiple datasets in a folder?
  • August 9, 2018
  • 89 views
Is there abilities to itierate through mutliple datasets in a folder? EG; I want to convert the format of multiple grid datasets so want to be able to build a simple FME process that runs for the first dataset, then runs for the seond, then third, etc.
I don't want to have to duplicate the simple FME process for each dataset I want converted.
fmelizard
Forum|alt.badge.img+18
  • August 9, 2018
Hi @aaronj. It is possible to read multiple datasets within a folder using FME.
I would suggest reviewing the following how-to articles, to see whether this approach would work for you:
https://knowledge.safe.com/articles/1157/dynamic-workflow-tutorial-destination-schema-as-a.html
https://knowledge.safe.com/articles/20203/how-to-read-all-feature-classes-from-multiple-esri.html
