Is there a way to use a counter as an increment as outlined below? Thanks
patmhid
I have a data set with multiple repeated values such as this
ADA
ADA
ADA
Benton
Canyon
Canyon
Dearborn
Dearborn
Dearborn
Dearborn
and I want to increment a count every time the preceding value is different than the next value.
so my 'count' would be like
1 - ADA
1  ADA
1 - ADA
2 - Benton
3 - Canyon
3 - Canyon
4 - Dearborn
4 - Dearborn
4 - Dearborn
4 - Dearborn
Best answer by bwn
markatsafe wrote:
@patmhid​ We don't have anything out of the bx. If you can order your features by the grouping attribute, then you can use the Adjacent Feature option in AttributeCreator to create group counts. I've attached an example workspace.
Similarly, that's the Solution I use in my Workspaces: Sorter + AttributeCreator
AttributeCreator
Enable Adjacent Feature Attributes: On
Prior Features: 1
Conditional Value: If @Value(GroupAttribute)=@Value(feature[-1].GroupAttribute) Then @Value(feature[-1].GroupID) Else @Value(feature[-1].GroupID)+1
The only thing I found was that at least in 2018.1, the FME Workspace Editor wants you to create the GroupID Attribute with a separate, preceding AttributeCreator first that initialises it to a default Dummy Value, otherwise an AttributeCreator that simultaneously tries to use Adjacent Feature Handling and create a new Attribute that doesn't yet exist in the Schema and is calculated using an Adjacent Feature Value will report itself as an "Invalid Transformer" in the workspace, even though it WILL run fine when executing the workflow!
virtualcitymatt
Forum|alt.badge.img+36
You could use an Aggregator to merge on that attribite​ (add all other attributes into a list) the a normal counter. After that use a list explode to get back to the original.
Alternatively you could use a sampler to get the first feature for each of the attributes you want to count and then count the features, you can then use a FeatureJoiner to ​join the count attribute back to the rest of the data.
I'm not sure if either of these are the best option, but they will work.
  • October 28, 2020
bwn
Forum|alt.badge.img+26
  • October 29, 2020
AttributeCreator
Prior Features: 1
Forum|alt.badge.img+39
  • October 29, 2020
I thought after yesterday's webinar you'd be recommending the InlineQuerier @Mark Stoakes​ :-)
select A.*, B.Rownum as Count from Table1 A,
(SELECT
    ROW_NUMBER () OVER (
        ORDER BY "Name"
    ) RowNum,
    "Name"
from
(select distinct("Name"from
Table1))B
where A."Name" = B."Name"
I've actually got a python based customer transformer that does the same thing that i really ought to get put on the hub
patmhid
  • October 29, 2020
Thank you. I tried this and it worked, but I am going to try the Adjacent Feature option in AttributeCreator to see if that is closer to what I will need going forward.
patmhid
  • October 29, 2020
Thanks, this did works great.
patmhid
  • October 29, 2020
AttributeCreator
Prior Features: 1
Thanks this is perfect!
  • October 29, 2020
(SELECT
        ORDER BY "Name"
    ) RowNum,
    "Name"
from
Table1))B
@ebygomm​  Haha... well I was just about to suggest that when the webinar ended unexpectedly!
bwn
  • October 30, 2020
(SELECT
        ORDER BY "Name"
    ) RowNum,
    "Name"
from
Table1))B
Small performance optimisation, particularly in SQLite based InlineQuerier.
Instead of:
  1. (select distinct("Name") from Table1)
Use
  1. (select "Name" from Table1 GROUP BY "Name")
Whilst they produce the same result, the query optimiser and the SQLite engine will generally execute faster with the query plan generated by GROUP BY.
Group Counter. FME 2021.1 Counter has been upgraded to include a group count.
New Counter dialog:
dialogresults:
