Is there a way to run more than one sql query in SQLCreator?
  • Feb 25, 2020 8:39 PM UTC
  • 184 views
michael_m
Forum|alt.badge.img+8
I am trying to modify an existing workbench which reads features from an Oracle database using an SQLCreator and writes them to a feature class in a geodatabase.
Currently there is a single query in the SQLCreator. I'm trying to add something to the output which requires a temporary table so I now need there to be three queries running in this SQLCreator:
Create temp_table;
Query to extract features from Oracle DB (and temp_table);
Drop temp_table;
Is it possible to run a series of queries in SQLCreator? If not is there some other way? The series of queries work fine when run directly against the database but I cannot get it to work in FME. My fallback is to create views in Oracle rather than using a temporary table but I'd rather not do that if I can avoid it.
Thanks,
Michael
Best answer by helmoet
Use
FME_SQL_DELIMITER ;
before all sql. See also discussion on this topic in this article
helmoet
  • Feb 25, 2020 8:42 PM UTC
Use
FME_SQL_DELIMITER ;
michael_m
  • Feb 25, 2020 8:55 PM UTC
Use
FME_SQL_DELIMITER ;
Many thanks, @helmoet!
