Is there a way to create polygonal viewport in autocad?
  • Dec 9, 2019 1:59 PM UTC
  • 6 replies
  • 186 views
I would like to create some viewports that are circular and also one shape like this
Is there an autocad attribute I can set to make viewports in irregular shapes?
Best answer by becchr
This was something on my ACAD-FME-todolist too, so I was intrigued by this question and started looking before I saw your answer @jovitaatsafe ...
After some puzzling with the format attributes of the viewport and the polygon, I managed to create a non-rectangular viewport! In addition to the do's and don'ts of this article, it comes down to specifying the handles (unique IDs or ACAD objects) of the viewport on the one hand and the 'clipping' polygon on the other and having them refer to each other using the attributes autocad_entity_handle, autocad_viewport_clipped_handle, autocad_viewport_non_rect_clip_handle. You must also indicate that there is a non-rectangular clip by setting the autocad_viewport_non_rect_clip attribute to Yes.
In the dwg writer you must also check the corresponding "format attributes" if necessary.
Handles are 64-bit integers, so displayed as hex strings they have a maximum of 16 digits. I’m not sure how handles are appointed to the objects by autocad, but it might be safer to choose handles at the end of the handle-spectrum… I just chose random values in this example that creates a non-rectangular viewport on layer ‘vp’ in Layout1 of the template dwg.
acad_PolygonVP.fmwt
Hope this helps @garydlester!
jovitaatsafe
Forum|alt.badge.img+11
Hi @garydlester,
//To my knowledge, I think we only read/create rectangular viewports according to the AutoCAD Viewports doc. It might be worth posting a new idea here to inform development of your interest. It would also be helpful to add in your idea why you might want to have viewports of different shapes to give us a use case. Thanks!//
Edit: My mistake, please see @becchr's answer highlighted below (:
becchr
Forum|alt.badge.img+35
  • Dec 11, 2019 9:24 AM UTC
acad_PolygonVP.fmwt
  • Dec 11, 2019 10:27 AM UTC
acad_PolygonVP.fmwt
@becchr This works perfect, thank you for showing an implement of autocad_entiity_handles, one more question, so if I want to do like a circular viewport I need like maybe 100 sided polygon? I tried to push an ellipse through and it failed, I will try with 100 side polygon later, thanks again!
becchr
  • Dec 11, 2019 10:59 AM UTC
hi @garydlester, glad it helps! indeed the circular viewport isn't working, while the autocad-settings seem to be the same, strange... Workaround could be indeed to use the ArcStroker transformer to make x-sided polygons from the circles.
sigtill
Forum|alt.badge.img+25
  • Dec 11, 2019 11:02 AM UTC
You can use the ArcStroker perhaps ? @garydlester
jovitaatsafe
acad_PolygonVP.fmwt
@becchr, nice work! I learned something new today! My apologies for the misinformation @garydlester, I'll update the comment to make it less confusing for any new readers coming by.
