Is there a way to check if a directory exists?
  • Mar 7, 2024 5:33 PM UTC
  • 511 views
gjaguilar
I create a directory B using the mkdir command within one SystemCaller and in another SystemCaller it copies file from directory A to B and it works.
But the process must copy copy new files that are created in directory A and the mkdir gives an error because the directory already exists.
hkingsbury
Forum|alt.badge.img+73
  • Mar 7, 2024 7:30 PM UTC
gjaguilar
  • Mar 13, 2024 7:10 AM UTC
Thanks a lot,
I used this transformer  (FileExistenceChecker) and everything worked fine.
