Is there a transformer to calculate the maximum enclosed rectangle? MER for label placement?
  • February 4, 2014
  • 31 views
I'm not looking for bounding box.  Rather the largest, axis-aligned rectangle that fits within the polygon.  Does this transformer exist?  If not, I can provide logic to implement.  Please let me know.
Best answer by sigtill
What about the option Oriented Bounding Box, does it help?
If not you can implement the logic in Python using a PythonCaller
sigtill
Forum|alt.badge.img+24
  • February 4, 2014
jdh
Forum|alt.badge.img+28
  • November 25, 2015
@loren I would be interested in the logic you would use to implement this.
gio
Forum|alt.badge.img+15
  • November 26, 2015
Oriented bounding box is not a MER of an object. Striclty speaking a MER would be the largest rectangle that one can possibly fit inside a object, iirespective of orienation. This is what you ask, but are satisfied with a OBBR?. I assume to orient labels to objects. There are different ways of finding a MER, involving quite some math. Easiest is brute force tchnique, requiring lots of calculationsteps.
