Is there a straightforward way to filter date/time attribute by a set period?
  • October 27, 2020
  • 757 views
I have a 10-year-long dataset that needs to be split by year. The complication in my case is that I need each output year to start from December of the preceding year, i.e. the output filter for year 2019 has to be from 01/12/2018 00:00 to 01/01/2020 00:00. I can't seem to get this to work with AttributeRangeFilter.
Cheers.
Best answer by ebygomm
I presume you've converted your dates to FME formats and are using that syntax in the AttributeRangeFilter?
Personally, I'd probably add a month to each date and then get the year and then filter by that single value.
Forum|alt.badge.img+38
  • October 27, 2020
  • October 27, 2020
I was just going to suggest the same thing. Keep it simple.
That's it! I have converted the original date/time from mm/dd/yy to dd/mm/yyyy, but have not used the FME format.
Everything works like a charm now, thank you muchly!
