Is there a possibility to reduce the number of triangles of a 3D Mesh generated with PointCloudSurfaceBuilder?
  • Dec 27, 2017 4:09 AM UTC
  • 5 replies
  • 104 views
erik_jan
Forum|alt.badge.img+26
  • Dec 27, 2017 6:14 PM UTC
I am not an expert in this, but would using the PointcloudThinner to reduce the number of points in the point cloud before using the PointcloudSurfaceBuilder help?
fmelizard
Forum|alt.badge.img+22
  • Dec 28, 2017 6:19 AM UTC
There is also a MeshGeneralizer (not sure if that will be its final name) being tested for potential inclusion into FME 2018. Short term @erik_jan's idea seems very sound.
  • Dec 29, 2017 1:09 PM UTC
Thanks for your answers. I already tested PointcloudThinner and PointcloudSurfaceBuilder as erik_jan proposed. The result is not bad, but I´m quite sure that it would be much nicer with the mentioned MeshGeneralizer. Let´s see whether this tool will be inculuded into FME 2018. Would be great!
  • Dec 29, 2017 1:48 PM UTC
Sorry, I didn´t use PointCloudThinner, but PointCloudSimplifier. This transformer thins the pointcloud considering its geometry.
fmelizard
  • Dec 29, 2017 5:22 PM UTC
Hi @batha7, I'm also not an expert in this, but perhaps the SurfaceDissolver in 2018 could help?
