Is the FileExistenceChecker able to recognize url-adresses?
  • February 18, 2019
  • 45 views
tschoppenhof
Forum|alt.badge.img+7
I tried the FileExistenceChecker to check fo a online xml-document but it seems that it can not check url adresses (result -> DoesNotExist). It didn't recognize an url-Adress that the xml-Reader is able to read (See attached Test Workspace). Any Idea what the problem could be?
nielsgerrits
Forum|alt.badge.img+55
I tested the URL of this topic and it gave me no results. As mentioned in the original topic you could use a HttpCaller to check the URL.
helmoetz
Forum|alt.badge.img+14
  • June 20, 2024
Not sure if FileExistenceChecker is able to check filenames with FME User Parameter references in it, like $(FME_SHAREDRESOURCE_DATA)/myfile.txt?
