Is it possible using FME / Python to detect a number in a PDF file and copy that number to the file name of the PDF and change it accordingly? Subsequently write the PDF file with the changed file number as output and save it on a specified location.
  • Sep 6, 2023 4:17 PM UTC
  • 63 views
sc1
The number always begins in the PDF file with "Registratienummer: the number I want to copy"
kailinatsafe
Forum|alt.badge.img+24
Hello @sc1​, thanks for posting! Sorry for not reaching out sooner, did you manage to get started on the process? FME and Python are likely both capable of this, but I think FME will work just fine. Are all of the PDF's your looking to process formatted similarly? or does formatting vary?
Take a look at this Getting Started with Reading PDF in FME article. Depending on if the data is spatial or non-spatial, you can use various PDF Reader parameters to control which text is interpreted as features. Nonetheless, happy to take a look if you're able to share a sample file. Best, Kailin.
sc1
  • Sep 11, 2023 9:16 PM UTC
Hi Kailin, thanks for your reply. All the PDF’s are formatted in a similar way and are non spatial. Does the above work as well with non spatial pdf’s or do I have to program a custom script?
kind Regards,
Sibe
kailinatsafe
kind Regards,
Sibe
Hello @sc1​, that's great news! Yes, the PDF Reader supports both spatial and non spatial PDFs, so not to worry. I've included a screenshot highlighting the Non-Spatial parameters available on the PDF Reader:
PDFReader_nonspatialparametersFeel free to reach out if there are any issues reading your data into FME Form. Best, Kailin.
