Is it possible to use a dynamic writer to update? I want to read multiple feature classes, join each feature class and then update the joined records in a different database. Matching columns are not available when selecting Update feature opera
  • Sep 1, 2020 2:50 PM UTC
  • 49 views
dkirouac
Forum|alt.badge.img+5
Is it possible to use a dynamic writer to update? I want to read multiple feature classes, join each feature class and then update the joined records in a different database. Matching columns are not available when selecting Update feature operation.
mark2atsafe
Forum|alt.badge.img+59
Yes this is possible. You're right, the attributes wouldn't be available on the writer parameters because the dynamic writer doesn't know what they're going to be until runtime.
So I think you have two choices:
  • Manually expose the attributes using the AttributeExposer transformer
  • Instead of picking the attributes, make a where clause in an attribute (like myWhereClause: myAttribute = myFieldName) and use that as a WHERE clause instead of a Match Column
Hope this helps.
