Is it possible to extract coordinates in Text-/Arithmetic Editor?
  • Nov 4, 2020 4:16 PM UTC
  • 5 replies
  • 68 views
jakomies
I need to do some comparison and tricks with z-coordinates in AttributeCreator transformer. Of course I can use CoordinateExtractor before AttributeCreator but it would be more useful to do the stuff inside AttributeCreator.
Something like (z-value for fourth coordinate in polyline) : @Evaluate($(fme_geometry).{3}.z)
drc43
Forum|alt.badge.img+13
  • Nov 5, 2020 4:51 PM UTC
It is possible. There are functions for X, Y, and Z coordinates in the FME Feature Functions. They can be used in either the text or arithmetic editor.coordinates
jakomies
  • Nov 6, 2020 6:15 AM UTC
Nope. Those functions returns the value of the first coordinate of the feature. You can't specify the sequence number of the desired point/vertex of the feature.
Forum|alt.badge.img+54
  • Nov 6, 2020 8:55 AM UTC
I think i might be missing something, yes it's one extra transformer, but why can't you extract the coordinates to a list and reference them in your AttributeCreator?
@Value(_indices{3}.z)
jakomies
  • Nov 6, 2020 2:06 PM UTC
Yes I can , but...
My actual need is quite complex with Huge datasets (not Big Data 😉).
I am using e.g. Conditional  Value. If certain conditions are met then z-coordinate is used. Only 4-5% of features meet those criteria's and z is needed. And only z, not x and y.  If I can skip CoordinateExtractor lot of time and system resources is saved.
  • Nov 6, 2020 2:15 PM UTC
Then it sounds like a tester to evaluate the first condition and then a coordinate extractor to only extract coordinates for those that meet the condition might save time in this instance, although more transformers required and perhaps not quite so neat workspace wise.
