Is it possible to apply a word wrap to text going into a PDF writer?
  • August 13, 2021
  • 213 views
bozboswell
Forum|alt.badge.img+7
I am creating PDF documents with a series of responses, so I first create a multi-line attribute then I pass that through the PDFPageFormatter and onto a PDF writer. The problem is some of the responses run off the page. I am needing to restrict the width of the multi-line attribute using something like a word-wrap function.
Any ideas?
Best answer by drc43
I highly recommend the Custom Transformer - TextWrapper. I had a similar problem and this solved it beautifully.
https://hub.safe.com/publishers/david-r/transformers/textwrapper
drc43
Forum|alt.badge.img+13
  • August 13, 2021
bozboswell
  • August 20, 2021
Thank you @drc43​ , that worked well.
