Intersected polygons and select highest related candidates for each combination
  • Jul 23, 2019 8:44 AM UTC
  • 34 views
a_afiaax
Within more than 2500 Features in one Polygon shapefile I used a SpatialRelator Transformer to find out intersected polygons followed by ListExplode Transformer. The result as following example:
My target is to select intersected features of highest related_candidates number (3 for above example). In some cases the highest related_candidates is 4 or more.
Does anyone have any ideas or potential solutions?
@mark2atsafe @egomm @david_r @jlutherthomas @jdh @takashi @redgeographics @danilo_fme
Best answer by caracadrian
You can use StatisticsCalculator with GroupBy set to FeatureID to get a maximum of the attribute you want followed by a TestFilter set to _related_candidates = _max_related_candidates.
caracadrian
Forum|alt.badge.img+23
  • Jul 23, 2019 12:08 PM UTC
