Inserting a text line at the start of CSV
  • Aug 14, 2014 2:19 PM UTC
  • 5 replies
  • 196 views
I have two CSV files which I want to merge.
File A has two lines.
File B is much larger and has many lines, preceded by a header.
Effectively what I want to do is create File C from a copy of File A with File B (minus it's header) appended onto it. I don't want to alter the data in any way.
thanks
IanM
  • Aug 14, 2014 2:36 PM UTC
first of all, I'd recommend using the Text File reader/writer rather than the CSV reader/writer for this.
Then look into the Sampler to skip the header of file B. Also insert a FeatureHolder on the features from file B to prevent them from being written before all the lines from file A have been passed to the writer.
David
gio
Forum|alt.badge.img+15
  • Aug 15, 2014 1:38 PM UTC
Or select relevant rows.
Renumber, sort and write.
Using "csv_line_number" exposed
Thanks, that's pretty much what I'm doing at the moment but the TEXT reader doesn't like a filename with .CSV so it's a little faffy ... get files, rename offline, run workspace, rename output offline
IanM
  • Aug 15, 2014 3:28 PM UTC
I believe the Text File reader can read any text file regardless of the extension. Try changing the filter of the Select File dialog into "All Files (*.*)".
Great. Thanks.
