Insert into multiples tables and manage foreign keys
  • Apr 16, 2019 2:02 PM UTC
  • 7 replies
  • 198 views
arnaud974
Forum|alt.badge.img+3
I need to insert data into different tables and some of them are linked by a relationship (example : a table that contains buildings and a table with the parcels). I need all the parcels to be insert into the database before to start the insert of the building as I want to know for each building the unique ID (generated by a PostgreSQL serial type) of the related parcel.
All my Readers are linked to a single FeatureWriter. Is there a way to specify that this feature writer must process the data one after the other (the order is defined by the list in featureTypes) ? Or any other possibility ?
Thanks
  • Apr 16, 2019 2:11 PM UTC
There are several ways of doing this, but personally I like using multiple FeatureWriters and chain them with a FeatureMerger set on a dummy merge criteria (e.g. 1 = 1).
The pattern looks like this:
This will ensure that the Master features have all been written and committed before the Detail features.
Here's also an article from Safe with some alternative strategies:
https://knowledge.safe.com/articles/44622/working-with-foreign-keys-writing-database-tables.html
arnaud974
  • Apr 17, 2019 9:29 AM UTC
Hi @david_r,
Thanks for your solution.
Could you please just show me a picture of the content of the dialog box of FeatureMerger please ?
I dont't understand very well where to put the dummy merge criteria.
Thanks
  • Apr 17, 2019 9:37 AM UTC
This is what I had in mind, simply typing the same hard-coded value in the Requestor and Suplier join criteria:
This would be what's often called an "unconditional merge", meaning that every requestor is joined with every supplier.
arnaud974
  • Apr 17, 2019 11:08 AM UTC
I'll try it and I'll let you know if it is working for me !
Thanks
arnaud974
  • Jun 5, 2019 7:51 AM UTC
Hi @david_r,
I've finally been able to find some time to test your solution.
Something is probably wrong with my settings as the process stops with this error raised: "EXTRA_REFERENCEE_FEATURE"
Do you have any idea on what is wrong ?
Thanks for your help
arnaud974
  • Jun 5, 2019 8:07 AM UTC
Hi @david_r,
I may have found a solution by activating "Process Duplicate Suppliers" and set Build Aggregates and the just after add a Deaggregator process.
It seems to work...
Would you have done it like that?
  • Jun 5, 2019 8:08 AM UTC
Hi @david_r,
The message means that you have more than one supplier for a requestor in the FeatureMerger. You can try enabling the option "Process duplicate suppliers" in the FeatureMerger. Try leaving the associated options as-is.
