InlineQuerier SQL random statement ("Random()", "Rand()", or "RND()"?) in conjunction with "LIMIT"
  • Nov 30, 2017 9:09 PM UTC
  • 90 views
bwasserstein
Participant
Hello All,
Question regarding the InlineQuerier transformer that harnesses SQL. I'm trying to select a random subset of records from a table. Here's the SQL code in MS-Access that works (different syntax).
SELECT TOP 200 *
FROM (SELECT Rnd(ID) AS RandomID, * FROM TableNameHere)  AS TableNameRandomSelection
ORDER BY RandomID;
I think the InlineQuerier uses SQLite...correct me if I'm wrong. I'm uncertain as to which random function I should use and where to implement it within the code string.
RND()? RANDOM()? RAND()?
And can I add an argument to this function? I need to generate a random sample of records based off the table's primary key ("ID" in this case).
This code works, but it only returns the first 200 records in the table (not the random sample I'm looking for), but I feel like I'm close and just need to work a random function in there...
SELECT *
FROM TableName
LIMIT 200
Forum|alt.badge.img+54
  • Nov 30, 2017 9:17 PM UTC
SELECT "ID" FROM "Table" WHERE "ID" IN (SELECT "ID" FROM "Table" ORDER BY RANDOM() LIMIT 200)
Something like the above should work
bwasserstein
Participant
  • Participant
A reply to my own post....Just FYI.
This works...
SELECT * FROM TableNameHere
WHERE ID IN (SELECT ID FROM TableNameHere ORDER BY RANDOM() LIMIT 200)
bwasserstein
Participant
  • Participant
  • Nov 30, 2017 9:19 PM UTC
Thanks egomm. Beat me to it :)
  • Nov 30, 2017 9:47 PM UTC
This works...
This query could work as well.
select * from tablename order by random() limit 200
