(I am using FME Desktop 2013 SP1 Build 13448)
Can InlineQuerier only be use to query the tables in their native data structure i.e. as they are in when they are initially read in? Or (ideally) can I use the transformer to query tables which I have alter part way through a workflow?
Ideally I want to read in some data, complete various processes and create a series of new attributes and then use the InlineQuerier to query some of new and original attributes. I am reluctant to create 1 workspace to read in the tables, create the attributes I need, then write the results to an intermediate file, and then create another workspace with the InlineQuerier elements?
I could use the FeatureMerger but this is really slow by comparison as I have to initially join all values from A to B and then subsequent filter, I have done this before but it is REALLY slow, and essentially can be completed using SQL Plus I am concerned that the process will run out of memory).
Any ideas this possible?
Regards,
Rob
