InlineQuerier query
  • September 5, 2018
  • 84 views
Hi
I am trying to use the InlineQuerier for the first time. I am using it instead of FeatureMerger because I want to do a join using a Like statement with wildcards which is not possible with FeatureMerger.
However I can't work out why my query is not running. I have done the same query within Oracle SQL Developer and it worked, but it is not working in InlineQuerier.
The query I've tried is below but I get a "Format and Dataset Unspecified" error when I try to run it.
SELECT b."POSTCODE",a."POSTCODE_AREA"
FROM "OS_POSTCODE_UNITS" b
INNER JOIN "TABLE1" a ON REPLACE (b."POSTCODE", ' ', '') LIKE CONCAT(REPLACE (a."POSTCODE_AREA", ' ', ''), '%');
Screenshot is also included.
I believe I have not set up the InlineQuerier properly in terms of the Input and Outputs, but I am struggling to understand what I am supposed to put here. Does anyone have a step-by-step example of how to use this transformer?
Regards,
Best answer by ebygomm
I don't think SQLite which the inlinequerier uses supports CONCAT try || instead
INNER JOIN "TABLE1" a ON REPLACE (b."POSTCODE"' '''LIKE REPLACE (a."POSTCODE_AREA"' ''')||'%'
If you could post a sample of your source datasets someone may be able to advise further.
Forum|alt.badge.img+38
  • September 5, 2018
  • September 5, 2018
Thanks @egomm
 I have changed the code to use the || operator instead but I still get the same error.  I have attached a screen shot of the Inputs and Outputs.  Are these set up correctly?
inlinequerier2.jpg,
  • September 5, 2018
aquamarine wrote:
Thanks @egomm
inlinequerier2.jpg,
Ah, that Run... button has never worked for me, I just run the workspace to see if it works
  • September 5, 2018
oh you are right! it does work even though the 'Run' button failed :) Thanks!
