inline querier not finding column
  • March 20, 2015
  • 135 views
tva
Forum|alt.badge.img+13
I'm using the inline querier to execute a sql statement but only if a certain condition is met (defined by tester).
I created my sql statement in MS Access and there it's working fine but when I use the same statement in the inline querier I get following error message:
ERROR |InlineQuerier_3(InlineQueryFactory): Error preparing database query: no such column: stop_times.trip_id Unable to execute statement
ERROR |InlineQuerier_3(InlineQueryFactory): Database was unable to prepare query 'SELECT *
FROM (route_max INNER JOIN (stop_times INNER JOIN stops ON stop_times.stop_id = stops.stop_id) ON route_max.trip_id = stop_times.trip_id) INNER JOIN (routes INNER JOIN Trips ON routes.route_id = Trips.route_id) ON route_max.trip_id = Trips.trip_id;
ERROR |InlineQueryFactory instance was not properly defined. Consult logfile for details.
This is the SQL statement I use:
SELECT *
For information about tables and columns see attached screenshot
What should I change in order to this to work?
My SQL knowledge isn't that great so what I do in the workbench is:
Run a first inline querier (this one succeeds with 4 outputs)
1 output = route_max (SELECT trip_id, route_id, Max(CountOfstop_id) AS MaxCountStops
FROM (
SELECT Stop_times.trip_id, Trips.route_id, Count(Stop_times.stop_id) AS CountOfstop_id
FROM Trips INNER JOIN Stop_times ON Trips.trip_id = Stop_times.trip_id
GROUP BY Stop_times.trip_id, Trips.route_id
ORDER BY Count(Stop_times.stop_id) DESC)
GROUP BY route_id); I connect with tester and via tester to new inline querier.
Regards
Tom
P.S. I'm using FME 2014 (SP4)
Best answer by takashi
Hi Tom,
Although the SQL syntax is basically standardized, there are variations in detail depending on database engines. Since the InlineQuerier uses SQLite internally, there are cases where a SQL statement works fine with MS Access but doesn't work with the InlineQuerier.
Probably this statement works as expected (hope there is no typo!).
select * from route_max
inner join stop_times on stop_times.trip_id = route_max.trip_id
inner join stops on stops.stop_id = stop_times.stop_id
inner join trips on trips.trip_id = route_max.trip_id
inner join routes on routes.route_id = trips.route_id;
In addition, if you test the statement with MS Access, you will have to surround join clauses by brackets, like this.
select * from (((route_max
inner join stop_times on stop_times.trip_id = route_max.trip_id)
inner join stops on stops.stop_id = stop_times.stop_id)
inner join trips on trips.trip_id = route_max.trip_id)
Takashi
  • March 21, 2015
Hi Tom,
Takashi
tva
  • March 23, 2015
Thank you Takashi, it's working good now.
