In my workbench I write multiple data to one excel file. Only then you get different tabs in excel, but I want everything in one tab. With a nice overview of headings and lines in between. Does anyone know how to do this in FME?
  • June 25, 2021
  • 71 views
ExampleThis is how I it get, with different tabs. And below is how I want it.
Example
muzhnasto
Forum|alt.badge.img+12
  • June 25, 2021
jkr_wrk
Forum|alt.badge.img+36
  • June 27, 2021
This is possible but I would recommend not to do it except when there is no other option. I hate datasets like this.
WB
You need to create a header feature, a row_number attribute, and rename all the other attributes to the column position. So rename Code to A, Status to B etc.
Then you need to merge the last features row_number to the second dataset and add this to the row_number of the second dataset.
The Excel Writer is set to:
Don't output attribute names, use attribute names as column position and Row number attribute = row_number.
I attached a working workbench.
