In amalgamating different pipeline datasets I need to identify which pipes are duplicated. The FuzzyParrelLineFinder is not reporting a match for for some pipes that have identical coordinates. In what situations does the FuzzyParrelLineFinder not
  • Mar 2, 2023 5:54 AM UTC
  • 71 views
philipwhitten
Forum|alt.badge.img+15
I am sending the FuzzyParrelLineFinder 3 features that are lines with 2 coordinates only (i.e. start and end points). The coordinates are identical. The lines are 64 m in length and I am using the parameters of: Sampling Distance = 1 and Search Distance = .30. The FuzzyParrelLineFinder is not identifying the lines as matching. Are there situations where the FuzzyParrelLineFinder doesn't work or have I miss-understood the parameters?
Best answer by markatsafe
@philipwhitten​ If you think there is an issue with the FuzzyParallelLineFinder then perhaps post a comment on the FME HUB for the author to take a look.
More recent versions of Matcher and ChangeDetector can use the Frechet distance when you set the Vector Tolerance under the Check Geometry panel, so you might want to try those.
  • Mar 2, 2023 7:27 PM UTC
daveatsafe
Forum|alt.badge.img+24
  • Mar 2, 2023 10:34 PM UTC
Hi @philipwhitten​,
The algorithm the FuzzyParallelLineFinder uses to match segments breaks down for perfectly coincident lines. I will need to update the transformer to catch that case and handle it properly.
daveatsafe
  • Mar 3, 2023 10:50 PM UTC
Hi @philipwhitten​,
FuzzyParallelLineFinder updated to properly handle coincident segments.
philipwhitten
  • Mar 5, 2023 10:20 PM UTC
Thank you. This question and answer forum is so helfpul. I learned about Frechet Distance and I realised that it was easier from other questions to compare the centre point, length and angle of my pipes to identify duplicates.
