Importing images to database text field ?
  • September 6, 2018
  • 74 views
lifalin2016
Forum|alt.badge.img+29
Hi.
I have been assigned the task of importing 4000+ images from a remote service into a local Postgres database. An obvious FME task.
Fetching the images with ImageFetcher runs smoothly, but here starts my problems:
- I need to store the MIME type, but although ImageFetcher is set to auto-detect this, it never reveals it in the output. And no file extension is available, and no other transformer offers that service, so an improvement to ImageFetcher is warranted, I think.
- I need to store the image in a text column in base64 format, but a combination of GeometryExtractor (FME Binary) + TextEncoder (Base64) doesn't really seems to work.
The output should look like this: data:image/jpeg;base64,/9j/........
Is there a better way to accomplish my task ?
Cheers
Best answer by ebygomm
Have you looked at using a HTTPcaller instead, you can store the response body directly as binary then and the response headers can be stored in a list
Forum|alt.badge.img+39
  • September 6, 2018
lifalin2016
  • September 6, 2018
Yeah, I got around to doing that. It seems like the only way.
Unfortunately, the output is still off, it seems, so maybe I'm still not getting the encoding right.
  • September 6, 2018
HTTPcaller with response body as binary followed by a BinaryEncoder should get the encoding right, then you just need to construct the output with the data from the headers
image-to-base64.fmw
01011010
  • January 29, 2019
image-to-base64.fmw
Can you insert into a MS SQL table (VARBINARY(MAX)) using SQLExecutor? if so how did you do it?
