Im looking at breaking all block references in a DWG down to the "level" where i only have 1 block that consists of geometry, instead of blocks containing blocks, keeping the transform of each block (im replacing it with proxymeshes in Unreal Engine)
  • Aug 26, 2021 10:41 AM UTC
  • 88 views
I have an idea about a collection of feature readers and writers (feature reader for DWG can break blocks 1 level. then checking if the entities resulting from that break is geometry ( ill keep the block containing that geometry from before the break) or if its a block (break again). then iterating over that until all i have is blocks that if breaked/exploded only consists of meshgeometry.
I would like to hear some feedback on this idea.
dr_snglr
  • Aug 30, 2021 11:58 AM UTC
Hello @oskarwallin90​
En example file would be helpfull, because the way I see it, the DWG reader explodes all blocks by default (recursively). It should do exactly what you describe:
Capture
Here is my workspace.
Maybe you can figure out what i am doing wrong.
I have DWG with alot of layers and blocks, consisting of blocks and geometry.
In the end, i want to find the location and rotation of all blocks that consists of geometry directly (not blocks that has blocks). then replace that point with a box representing the transform of the original block.
Ex. I have a tree. Fruit on that tree is "Geometry".
The tree trunk is a block that has branches (Blocks).
the branches has Twigs(blocks)
and the Twigs has fruit(Geometry).
I want to find all the Twigs in the tree, get their position and rotation and switch them out to something else.
I hope it makes sense
Best Regards
Oskar Wallin
