Ignore value of 0 in ExpressionEvaluator
  • Mar 12, 2018 2:30 PM UTC
  • 183 views
mattenvsys
Forum|alt.badge.img+4
Hi, I'm trying to evaluate if multiple columns in a single row are populated with values and then count how many columns have a value.
For example:
COLACOLBCOLCCOLDCOUNT0000042010276210030001571
I used the ExpressionEvaluator with the following expression:
COUNT = (COLA/COLA)+(COLB/COLB)+(COLC/COLC)+(COLD/COLD)
But obviously dividing by 0 is throwing the whole result off. Is there some form of COUNTIF in FME?
Are you able to suggest a better solution / fix my expression to ignore dividing by zero?
Any help would be greatly appreciated. My brain has decided to give up today...
Best answer by jdh
There is the math operator ? :
(x?y:z) If-then-else. If x is non-zero, then the result is the value of y, and if x evaluates to zero, the result is the value of z.
So something along the lines of (@Value(Cola)?1:0)+(@Value(Colb)?1:0)+(@Value(Colc)?1:0)
You could also look at the ideas from https://knowledge.safe.com/questions/54902/contif-equivalent-function-in-fme.html
jdh
Forum|alt.badge.img+41
  • Mar 12, 2018 2:48 PM UTC
mattenvsys
  • Mar 12, 2018 3:03 PM UTC
Thanks, that's sorted it. I was searching for anything related to expression evaluators and ignoring 0/null values before making this post
