IFC_API Reader in FME 2025.1.1 fails to read features, reads Types only
  • Aug 30, 2025 1:39 AM UTC
  • 267 views
iii4625
Hello,
I am currently learning how FME handles IFC HVAC structures and have been using some sample files from the RWTH-E3D DigitalHub repository (https://github.com/RWTH-E3D/DigitalHub) for my tests.
While doing this, I'm having trouble getting FME to read all the features and their geometry correctly.
The IFC file itself appears to be valid, as it displays correctly in an external IFC viewer like BimVision. (filename: DigitalHub_FM-HZG_v2.ifc)
Here you can see the full HVAC system with pipes, tanks, pumps, etc.
However, when I bring it into FME, I get incomplete results, and the behavior is different depending on the version I use.
1. With FME(R) 2025.1.1.0 (Build 25615):
The reader fails to read most features. The feature count for IfcPipeSegment, IfcTank, IfcPump, etc., is 0. The FME Inspector confirms that nothing is read.
2. With FME(R) 2025.0.3.0 (Build 25241):
This older version is partially successful:
It correctly reads features like IfcPipeSegment and IfcTank with their geometry.
However, for features like IfcPump, IfcValve, and IfcSensor, it reads the features (the feature count is correct), but their geometry is NULL.
As you can see here, the geometry for valves, pipe fittings, or other components located between pipes or at the ends of pipes is missing.
Is there perhaps a new reader parameter I need to adjust in the latest version to get the features and geometry to read correctly?
I did not find any related warnings or errors in the Translation Log either.
Any advice would be greatly appreciated.
Thank you.
Best answer by desiree_at_safe
Hi ​@iii4625
Thank you for the detailed testing! I’ve repro this issue and I can confirm there’s a change in behavior in 2025.1.1 compared to 2025.0.3, particularly when reading the feature types you’ve mentioned, like PipeSegment, PipeFitting, and Tank.
This is caused by a known issue with the IFC reader that has been identified and we can expect better results for FME 2025.2. However, given the workflow impact you've described, the development team is working to expedite this fix. You can also look for a beta build for testing workflows when that becomes available.
Thanks again for the thorough testing and feedback! It really helps us prioritize and identify improvements 😊
[INTERNAL: FMEENGINE-87869]
desiree_at_safe
Forum|alt.badge.img+25
Hi ​@iii4625
iii4625
  • Sep 13, 2025 10:45 AM UTC
Hi ​@desiree_at_safe
Is this an issue that has been resolved in the beta version?
I would like to share a few things I have found out regarding this problem.
The issue where only the Type Feature is read seems to be related to geometry rather than to a specific IfcEntity. First, I found that the same symptom occurs not only with HVAC-related features but also with other features. In addition, when a feature read by the IFC reader (deprecated) is written back to an IFC file using the IFC writer (deprecated) and then read again with the IFC_API reader, the feature is successfully read.
desiree_at_safe
Hi ​@iii4625, yes those improvements should’ve been made to the Beta! We weren’t able to backport fixes but I’d really encourage testing out the beta version:
https://fme.safe.com/downloads/#beta
Did you happen to notice the feature type - geometry issue connection while on the Beta?
