Identifying intersected lines from different datasets
  • Jan 30, 2019 3:13 PM UTC
  • 370 views
jugoslaviaa
I have two datasets . Both of them consist of linestring. One data set is street centerline and the second one is the left and righ side of the street. I would like to find the lines in second dataset where they intersect with lines in the first dataset.
It is pretty straight forward. I can do it in QGIS with help of spatial query. However, I am not able to identfy those lines correctly. Both Spatial Relator and Spatial Filter find some of the disjoint lines as intersected. I do not know what I am doing wrongly.
I would be very happy, if someone could help me. Thanks in advance.
Here is the snapshot how my two datasets look like. I would like to find the intersection as marked in the pic.
This is how the workbench and spatial filter parameter lok
Here one can see the lines that are detected as intersected however they are not even touching each other.
Those lines are however identfy correctly as intersected.
Best answer by daveatsafe
Hi @jugoslaviaa,
In the SpatialFilter, please change the Support Mode to Support All Predicates, then change the Spatial Predicates to Test to 'Filter Crosses Candidate'. If you have any aggregates in your source geometry, you will need to use a Deaggregator before the SpatialFilter. This should find all the crossing lines.
danilo_fme
Forum|alt.badge.img+58
  • Jan 30, 2019 8:31 PM UTC
Hi @jugoslaviaa
Did you try to use the transformer Intersector?
Thanks,
Danilo
danilo_fme
  • Jan 30, 2019 8:52 PM UTC
Hi @jugoslaviaa
Thanks,
Danilo
Interesting link
https://knowledge.safe.com/questions/2351/line-intersect.html
daveatsafe
Forum|alt.badge.img+24
  • Jan 30, 2019 9:57 PM UTC
Hi @jugoslaviaa,
jugoslaviaa
  • Jan 31, 2019 10:56 AM UTC
Hi @jugoslaviaa,
It worked! Thank you very much. I knew that I am doing something wrongly. I have both add the deaggretor and change the parameter in the filter. I kept both cross and intersection and the output is as I expected now.
